UltraBar Kickstarter FAQ Summary For Future Backers: Newcomer Guide & Frequently Asked Questions
# UltraBar Kickstarter FAQ Summary
**For Future Backers: Newcomer Guide & Frequently Asked Questions**
## Table of Contents
1. [Product Colors & Color Options](#1-product-colors–color-options)
2. [Hardware Specs & System](#2-hardware-specs–system)
3. [Features & Integrations](#3-features–integrations)
4. [Developer Support](#4-developer-support)
5. [Product Roadmap](#5-product-roadmap)
## 1. Product Colors & Color Options
### Q: What color options are available?
**A:** The product offers the following color options:
| Type | Color | Additional Cost |
| Body Standard Color | Deep Space Gray | Free |
| Body Standard Color | Silver | Free |
| Body Premium Color | White | +$8 |
| Body Premium Color | Blue | +$12 (CoreBar) / +$8 (Other versions) |
| Button Color | Black / Silver | Free |
> Note: The first production batch focuses on Deep Space Gray. White and other colors are being considered for future production.
### Q: Why do some color options require additional payment?
**A:** The initial crowdfunding campaign only planned one body color (Dark Gray). Due to enthusiastic backer feedback, the team expanded to four complete color options. White and Blue require additional custom processing and color matching, resulting in附加成本. Silver and Dark Gray remain free.
### Q: Can I customize button colors?
**A:** Yes! DotKey buttons are available in Black and Silver. In the pre-shipment survey, you can lock in your final selection.
### Q: How do I choose the color for the Christmas Mystery Box?
**A:** The Christmas Mystery Box is now available as an add-on option:
- Dark Gray and Silver: No extra charge
- Blue and White: +$8
The mystery box will match the color of your main order.
### Q: Can I see photos of the actual product colors?
**A:** Since the product is still in production, there are no physical units available yet. Once production is completed, the team will release photos and live images of all color variants.
## 2. Hardware Specs & System
### Q: What operating system does the product use?
**A:** UltraBar runs **LineOS** — a proprietary operating system deeply customized by the team based on AOSP (Android Open Source Project) for desktop interaction scenarios. It is not a direct fork of LineageOS.
LineOS Features:
- Core apps optimized for bar-shaped screens
- Embedded API service layer (supporting Home Assistant, Philips Hue, Sonos)
- Future dedicated UltraBar app store ecosystem
### Q: Does the power adapter support global use?
**A:** Yes! The product includes a DC 12V power adapter with interchangeable plugs (US, EU, China). The CoreBar’s USB-C port also supports PD fast charging, allowing you to use your own PD-compatible charger or power bank.
### Q: Can USB-C be used for video output as a secondary monitor?
**A:** The current USB-C port doesn’t support direct video connection (no USB 4/5 support). The team is evaluating adding an HDMI-IN chip to the Android motherboard for secondary screen functionality, but this hasn’t been finalized yet. A daughterboard solution may be implemented in the future.
## 3. Features & Integrations
### Q: Does the product support AIDA64?
**A:** Yes! UltraBar fully supports AIDA64. Through the Windows companion app, CoreBar can read system monitoring data (CPU/GPU temps, load, fan speeds, etc.) directly from AIDA64’s shared memory and display it on screen in real-time.
### Q: Does it support Home Assistant?
**A:** Yes! UltraBar natively supports Home Assistant, with deeper control available through LineOS firmware updates.
### Q: Does it support Nanoleaf smart lights?
**A:** Yes! There are two ways:
1. **Via Home Assistant**: Add Nanoleaf lights to HA and control them directly from UltraBar screen
2. **Via LineOS**: Direct support through software update
### Q: Can it control TVs/projectors?
**A:** Yes! Through Home Assistant integration, you can control supported TVs including LG. For example, LG G4 TV power and other functions can be controlled via HA.
### Q: Can it wake up a TV (not just a PC)?
**A:** Yes, this can be achieved through Home Assistant integration.
### Q: Does it support Wake-on-LAN?
**A:** You can send WOL commands directly from CoreBar without Home Assistant. One requirement: You need a USB-C to Ethernet adapter (CoreBar doesn’t have an Ethernet port). Note: The device must be on the same wired LAN as the target device for reliable operation.
### Q: Can it run independently when the computer is off?
**A:** Yes! CoreBar is an independent Android device. Even when your computer is off, its core functions (like controlling smart lights, stereos, or running automations) remain fully active. It’s designed to be the always-on intelligent hub of your desk.
### Q: What languages are supported?
**A:** Multi-language support is planned, including:
- **GUI Translation**: Language packs delivered via software updates, community translation contributions welcome
- **Cyrillic Support**: Russian text display has been tested and confirmed to work correctly
- **Voice Assistant**: Supports recognition for multiple languages, will be enabled gradually through updates
### Q: Does it support Linux?
**A:** Yes! The team plans:
1. Build configuration software using Qt cross-platform framework; official Linux client is core to the development roadmap
2. Hardware uses standard USB and HID protocols, essentially plug-and-play
3. Will provide complete open API and SDK
### Q: Does it support state-aware system controls (like showing mic mute status)?
**A:** Planned! This is a high-priority feature. Future CoreBar will be able to:
- Display real-time status of microphone, camera, DND, VPN
- Toggle these settings directly from the screen
- Achieve bidirectional communication through PC companion app
### Q: Does it support KVM switching functionality?
**A:** Requires a dedicated KVM control module connected to CoreBar via Bluetooth Mesh. Users can manage KVM operations directly from CoreBar interface and one-touch computer switching. Specific specifications (number of monitors and computers supported) haven’t been finalized yet.
### Q: Does it support professional users (Business/Power-User mode)?
**A:** Planned! While not in the initial release, “Power-User mode” is a clear high-priority product roadmap objective, including:
- Minimal animations and maximum responsiveness
- Clear action confirmations
- Predictable UI behavior
- Optimized information density display
### Q: How does SenseCube presence sensing work?
**A:** SenseCube combined with SceneShift™ engine can:
- Detect if you’ve stepped away from your desk
- Trigger non-intrusive reminders when you leave during a call
- Visually display “Away” or “Idle Time” status
- Detect ambient light changes and environmental vibrations
All sensing rules are disabled by default and fully controlled by the user.
## 4. Developer Support
### Q: Can I 3D print custom housings?
**A:** Yes! The team will provide:
- Detailed mechanical reference files (side views, key dimensions, 3D models)
- Pogo Pin connector electrical specifications and communication protocol documentation
This means you can not only design passive holders but also create active intelligent modules that physically connect to UltraBar, draw power, and communicate with the system.
### Q: Will you provide open API/SDK?
**A:** Yes! Plans include:
1. First release official configuration software to establish stable feature core
2. Then release public API and SDK
3. WebSocket API and WebHook support will be provided
### Q: Do you plan to support AutoCAD?
**A:** Yes! The team plans deep AutoCAD integration, allowing DialKey and DotKeys to control common tools like zoom, pan, layer switching, and more.
### Q: Is there dedicated support for filmmakers?
**A:** Yes! UltraBar can:
- Visualize shortcuts as icons on the strip screen
- Execute composite operations like “split and add transition” with DotKey mechanical buttons
- Achieve precise parameter adjustments with KnobKey physical dials (map to color temperature, exposure, saturation during color grading)
- One-tap switch between “Editing Mode,” “Color Grading Mode,” “Effects Mode”
- Implement distributed control console layout via VivoCube
## 5. Product Roadmap
### Q: Will there be more modules and expansions?
- Expandable dynamic-icon button arrays (2x2 layouts)
- More professional interaction modules: faders, encoders (knobs)
Expected to officially launch in H2 2025.
### Q: Will you attend CES 2026?
**A:** Unable to secure suitable exhibition space, unable to attend CES 2026. However, the team has showcased physical products at:
- IFA Berlin (Europe’s largest consumer electronics fair)
- ES Electronics Show in Brazil
- Global Maker Faire Shenzhen
### Q: Where will the product be sold after crowdfunding?
**A:** After crowdfunding ends:
- Priority shipping to backers
- Available on https://www.sanytron.com
- Planned Amazon listing (timing TBD)
### Q: Why was the funding goal set so low?
**A:** The lower funding goal was based on marketing advice, helping with platform ranking and visibility. This is the team’s first crowdfunding campaign. The lack of experience caused misunderstanding. Please rest assured the project is real and the team is fully committed to delivery.
## Useful Links
- YouTube Demo Videos: https://youtu.be/m0EHRbSpM9o | https://youtu.be/bAbNCLVRqlE
- Official Website: https://www.sanytron.com/
- Product Website: https://www.ultrabarx.com/
## Communication Tips
1. **Contact the team**: Via Kickstarter private message
2. **Response time**: Usually 1-3 business days, may delay during Chinese New Year
3. **Important questions**: Public comments are recommended; other backers’ questions and answers may help you
4. **Urgent matters**: Mark as “urgent” and the team will prioritize
**Hope this summary helps you! Wishing you an enjoyable experience.**
