Struggling to get setup
Hi Folks,
I’ve just set up my Astrion remote and I’m stuck on getting the view to show.
My setup:
  • Latest Home Assistant
  • RosCard installed via HACS (latest version)
  • Remote is connected to HA successfully (same local network)
  • Long-lived access token created and scanned via QR code
What I’ve done:
  • Created a new dashboard called “Remote”
  • Added a RosCard light card (custom:aiks-light-card) with 3 living room light entities
  • Saved the card
  • Tried refreshing on the remote multiple times
Dashboard YAML:
  • type: sections
    sections:
    • type: grid
      cards:
      • type: heading
        heading: New section
      • type: custom:aiks-light-card
        entities:
        • entity_id: light.ceiling_light
          uuid: 1cff20f3-7ad8-4566-9764-51df87903824
          alias: ‘’
          independent_display: false
        • entity_id: light.living_room_uplighter
          uuid: 26be89e6-32d8-43b0-9171-b591401474db
          alias: ‘’
        • entity_id: light.living_room_floor_lamp
          uuid: 1793d96c-33c5-4a82-b1c0-8a35854d0b2b
          alias: ‘’
The remote screen shows “View is empty - Configure the view in Home Assistant” with a blue toast saying “The view is empty. Please create a view in HA”.
What am I missing?
Your remote software version and firmware version most likely needs to be updated.
  • Pull down from the top of the screen on the remote.
  • Select (Set) Settings
  • Select About
  • If your Software and Firmware versions need to be updated a red dot will show.
  • Updating the Software version should fix your problem.
Current software version is V1.1.4
Thank you. i figure it out, It was because i didnt give the view a name. all sorted now, thank for your help.
