šŸ” Security discussion: tokens, access control & remote access
Let’s discuss security best practices:
  • Long-lived access tokens
  • Token rotation
  • Multi-remote setups
  • Remote access risks
This is a technical discussion, not general usage.
Environment
  • Sanytron Remote: Astrion
  • Sanytron Firmware: 1.0.38 / 2025111416
  • Home Assistant: Running with HTTPS enabled (via reverse proxy)
  • Network: Enterprise network with security policies
Issue Summary
I’m unable to configure the Sanytron remote to connect to my Home Assistant instance. The remote appears to have two separate issues with URL handling.
What I’ve Tried
1. Using Domain Name URL
URL entered: https://homeassistant.example.com/api/
Result: INVALID_URL_FORMAT error
The remote rejects any URL containing a domain name. Only IP addresses appear to be accepted.
2. Using IP Address with HTTPS
URL entered: https://[REDACTED_INTERNAL_IP]/api/
Result: Connection fails (TLS certificate error)
This fails because the SSL certificate is issued for the domain name, not the IP address. This is expected behaviour for properly configured HTTPS.
3. Using IP Address with HTTP
Not possible - Home Assistant server only accepts HTTPS connections (as it should for security).
The Problem
The remote creates an impossible situation:
URL Type Protocol Result
Domain name HTTPS :cross_mark: INVALID_URL_FORMAT
IP address HTTPS :cross_mark: TLS certificate mismatch
IP address HTTP :cross_mark: Server doesn’t support HTTP
Note on redacted information: Internal IP addresses and domain names have been redacted for security. These are valid, correctly formatted addresses - the redaction is not masking malformed input.
Network Context
Our network implements standard enterprise security practices, including:
  • Blocking outbound connections to known telemetry/tracking services (ā€œphone homeā€ blocking)
  • DNS filtering for IoT devices
  • HTTPS-only internal services
The remote can reach internal services (we’ve verified network connectivity), but the URL parsing/TLS handling prevents successful connection to Home Assistant.
Questions
  1. Is there a firmware update that adds support for domain names in URLs?
  2. Are there alternative integration methods (local API, different URL format)?
Device Information
The remote broadcasts itself as an Android device via mDNS. If helpful for diagnostics, I can provide additional network-level information about what the device is attempting to connect to.
ā€œCannot Connect to Home Assistant via HTTPS – TLS / URL Issuesā€
Replying as Sanytron team
Hi Troy, welcome to the community — and thank you for such a clear, well-structured report. This is very helpful for diagnosis.
First, we want to acknowledge that your analysis is correct. The situation you described does indeed create a dead-end configuration when Home Assistant is deployed using HTTPS with a domain-based certificate, which is a very common and correct security setup.
Let me respond point by point.
:small_blue_diamond: Current behavior (confirmed)
At the moment, Astrion’s HA connection logic has the following limitations:
  1. Domain names in the HA URL
  • Currently, the URL parser only accepts IP-based formats
  • Domain-based URLs (even when valid) may trigger INVALID_URL_FORMAT
  • This is a known limitation in the current implementation
  1. HTTPS with IP address
  • As you correctly noted, TLS certificates issued for a domain will fail validation when accessed via raw IP
  • The TLS failure you observed is expected and standards-compliant behavior
  1. HTTP fallback
  • Astrion does not downgrade HTTPS to HTTP
  • If HA is HTTPS-only (as it should be), HTTP is not a viable workaround
So yes — in enterprise or security-focused environments, this combination currently makes it impossible to complete the connection. Your summary table accurately reflects the problem.
:small_blue_diamond: Why this exists (context, not an excuse)
Some of these constraints originate from:
  • Early-stage assumptions around local-network HA deployments
  • Simplified URL validation logic
  • Conservative TLS handling choices made before broader enterprise use cases emerged
Your report clearly shows that these assumptions no longer hold for many advanced users.
:small_blue_diamond: What we are doing next
Your feedback has been recorded and escalated internally, and we are actively discussing improvements in the following areas:
  • :white_check_mark: Support for domain-based HA URLs
  • :white_check_mark: Improved HTTPS / TLS handling
  • :white_check_mark: Clearer validation and error reporting during connection setup
At this stage, we can’t yet commit to a specific release version or timeline, but this issue is now formally tracked and recognized as a real limitation, not a configuration mistake on your side.
:small_blue_diamond: Alternative integration paths (short term)
At present:
  • There is no separate local API or alternative URL format that bypasses this limitation
  • mDNS visibility alone is not sufficient to complete authenticated HA pairing
If you’re willing to share additional diagnostics (for example, TLS handshake behavior or connection attempts observed at the network level), that information would be genuinely useful and welcome.
Thanks again for the professional and responsible way you raised this. Reports like yours directly influence how we evolve Astrion beyond simple home networks and into more secure, real-world deployments.
We’ll update the forum once we have concrete progress on this topic.
Hi Sanytron team,
I have the same setup with a domain-based HA URL using HTTPS with a valid SSL certificate. This isssue is preventing me to consider the Astrion remote for all my HA projects. I really think this remote is the best implementation of HA remote control in the market right now, but this issue will prevent professional smart home projects from using the Astrion. Please give this issue a higher priority in order to enable the connection between HA and Astrion via HTTPS using a domain-based HA URL with a valid SSL certificate.
Alvaro
I’m also affected by this. Not a business, just a regular customer, but using https and a dynamic dns is the only easy(-ish) way to access my smart home from my phone when I’m away from home.
It’s been way too long since I did any proper programming (so apologies for the backseat driving), but I know that libcurl has options to ignore SSL security checks. For example, the curl command to my https://192.168.1.175:8123 HA box gives an SSL error (ā€œno alternative certificate subject name matches target ipv4 addressā€), but running Ā«curl --insecure https://192.168.1.175:8123Ā» pulls the page. I think maybe that the documentation at ā€œhttps://curl.se/libcurl/c/CURLOPT_SSL_VERIFYPEER.htmlā€ could be relevant.
But even if you’re using a different library, there’s likely a similar means to do the same thing. And obviously it’s a terrible idea to make this a default on an in-production product, but I’d really like it if there were a switch somewhere I could use to make this a voluntary insecure option, even with lots of ā€œAre You Sureā€ dialogs to click past. Until this, my Astrion is just a useless slab laying on a coffee table.
Anyway, don’t know if there’s anything I can do to really help. I could paste outputs from curl on my laptop (–verbose does give some TLS handshake details), but no clue if that’s actually useful.
@jcholewa @ajguerre
Hi Alvaro, jcholewa, and everyone following this thread,
Thank you very much for taking the time to explain your setups and concerns so clearly. We want to be very direct here: this is an important issue, and we fully understand why it blocks both professional projects and advanced Home Assistant users.
:white_check_mark: Acknowledgement & priority
You are absolutely right that:
  • Domain-based Home Assistant URLs
  • HTTPS-only setups
  • Valid SSL certificates
    are standard practice today — especially in enterprise networks, professional smart home deployments, and remote-access scenarios.
This limitation is not acceptable long-term, and we have already elevated this internally as a high-priority item.
:magnifying_glass_tilted_left: Current status (what’s happening today)
At the moment, Astrion:
  • Performs strict URL format validation
  • Enforces TLS certificate verification
  • Does not yet accept domain-based URLs in the HA endpoint configuration
This combination unfortunately creates exactly the ā€œimpossible triangleā€ that Troy and others described earlier:
  • Domain + HTTPS → rejected at URL validation
  • IP + HTTPS → certificate mismatch
  • HTTP → not allowed (and correctly so)
So yes — you’re seeing a real limitation, not a misconfiguration on your side.
:brain: About the ā€œinsecure / ignore TLS errorsā€ suggestion
jcholewa, thank you for the concrete example and for referencing libcurl options — that’s helpful context.
From a product and security standpoint:
  • We cannot enable ā€œignore SSL verificationā€ as a default behavior
  • We do understand the request for an explicit, opt-in, advanced setting, clearly marked as insecure, for controlled environments
This approach is currently under discussion internally, including:
  • Whether it should be hidden behind an advanced / developer toggle
  • How to ensure users fully understand the security implications
  • How this interacts with future OTA updates and platform compliance
No promises on the final form yet — but the idea itself is reasonable and noted.
:hammer_and_wrench: What we are actively working on
The engineering team is currently evaluating:
  1. Proper domain name support in HA endpoint configuration
  2. Improved TLS handling, including correct hostname validation
  3. Clearer error reporting, so failures are easier to diagnose
  4. How to support professional / enterprise HA deployments without compromising baseline security
Once an implementation plan is finalized, we will:
  • Post an official update in the forum
  • Clearly document supported configurations
  • Explain any limitations or required setup steps
:handshake: Thank you (genuinely)
We also want to say this clearly:
The level of feedback in this thread is exactly what helps us mature Astrion from an enthusiast product into something that can be confidently used in professional smart home projects.
Your points are well-argued, technically sound, and taken seriously — this is not being brushed aside.
If anyone is willing to:
  • Test beta firmware later
  • Share anonymized TLS handshake logs
  • Or validate fixes in real HTTPS/domain environments
…that will be extremely helpful, and we’ll reach out when we’re ready.
Thank you again for your patience and for holding us to a high standard.
