Newbie questions
Hi,
looking for help with these quesions:
  1. How do I link an Astrion button with a HA script?
  2. Is there support for horizonal stacks, ie. 2 or more ros cards displayed in a row on the remote? Any other customizable layout support?
  3. What is a ROS Host Control Card used for?
  4. What is a ROS Monitor Card used for?
  5. The Media Player Control Card volume up/down step of the remote volume buttons is quite large. Can this be changed?
Thanks
Hi starob,
Great questions — welcome! I’ll go through each one step by step so you have a clear overview of how things work today and what options you have.
1. How do I link an Astrion button to a Home Assistant script?
You can bind a physical button through the Shortcut / Button Binding settings:
Typical flow
Remote button → Shortcut binding → HA entity/service → Script executes
To do this:
  • Create your script in Home Assistant
  • Expose it as an entity/service
  • Assign it to a shortcut/button action in the remote configuration
Once linked, pressing that button triggers the script instantly.
2. Horizontal stacks / multiple cards per row
Currently, RosCard layouts are primarily vertical-stack oriented for readability and touch usability on the remote screen.
At the moment:
  • True horizontal card stacking is not yet a native layout option
  • Layout customization is somewhat constrained by screen scaling and UI density optimization
That said, more flexible layout systems (including multi-column/grid-style arrangements) are under evaluation for future versions because many advanced users have requested this.
3. What is a ROS Host Control Card?
A Host Control Card is designed to control a parent or host device/service rather than a simple entity.
Typical use cases:
  • System-level commands
  • Mode switching
  • Master device state control
  • Triggering higher-level automation logic
Think of it as a controller for logic layers, not just a single device.
4. What is a ROS Monitor Card?
A Monitor Card is mainly for displaying status information rather than controlling devices.
Examples:
  • Sensor values
  • System stats
  • Status indicators
  • Read-only data feeds
It’s useful for dashboards where you want quick system visibility without interaction.
5. Media Player volume step too large
You’re correct — the volume step size comes from the underlying media entity’s configured step value.
Possible solutions:
  • Adjust the volume step in the Home Assistant integration (if supported)
  • Wrap volume commands inside a script and bind buttons to that script with custom step logic
  • Use repeated small-step service calls instead of default volume_up/down
Native adjustment for volume increment size directly on the remote side is a reasonable request and something we’re considering adding as a configurable parameter.
Extra tip
RosCard currently supports nine control categories (lighting, climate, curtains, media, scenes, statistics, etc.), so depending on your use case you may find a built-in card that already fits your workflow. Our knowledge section posts, manuals, and tutorial videos include configuration examples that can be very helpful when setting up advanced layouts or logic chains.
Thank you Charles. How do I expose a scripts so that I can link it to a button in the remote? I don’t see any of my scripts listed as options to create such a link.
The software shown in the video seems to support swiping sceens. Mine does not. Is this a newer version? What are the latest software versions?
I have:
  • Software Version 1.1.0
  • Firmware Version 2025111409
  • ROSCard Version 1.0.8
No updates are offered at the moment for my device.
Thanks.
Hi Charles,
still struggling with the Host control card. I can only select “remote” entities in the UI but the card does not show on the Astrion. I can link it to a button though but it doesn’t do anything.
please forget the host card since it require the AIKS or Link-On AV controller for test, we will develop this card for new application
Hi @starob
As a test for the host card the remote entities dont show up for me either however if i manually add switch entities it does show up and work. The host card is filtered to remote entities.
What I also noticed with the host card is somethimes it does not sync correctly. To fix this i had to rearrange the cards in the UI and sync again and it showed up.
type: custom:aiks-host-card
entities:
  - entity_id: remote.bravia_kd_65a8g
    uuid: 70d2848b-d765-4fc0-b536-60044022739e
    alias: ""
  - entity_id: remote.universal_remote
    uuid: 29ffe877-65a0-4aa2-b52b-5dd27878c45a
    alias: ""
  - entity_id: switch.clear_voice
    alias: ""
    uuid: 3d01da5a-0960-4582-89c4-0a93c3ba9b00
  - entity_id: switch.dishwasher_power
    alias: ""
    uuid: dfdd413a-2b11-4a20-b380-2879379c9f23
