I have an LG TV running WebOS. I want to control it using the Sanytron remote. The TV card is asking for Android or Apple TV but there is no option for WebOS. How can i setup LG TV with this remote?
Thanks
Thanks
I control my LG WebOS TV using the Astrion to control my Logitech Harmony Hub. You would have to purchase an IR Transmitter that can be connected to HA.
I do have a harmony hub which i was hoping to replace with this remote.
What card do i need to use for this remote to allow control of the LG TV via harmony hub?
As far as I can see the Apple TV/android TV just changes the menu and buttons available slightly.
Can you currently control the TV from within home assistant? If so just assign the controls to match and it’ll work.
I have an LG TV and while I haven’t implemented any control yet as I only ever touch the TV remote when a firmware update is needed, the way I would implement it would be to use the LG WebOS integration and a translation script for each button available in the WebOS integration, details available here.
one script per button is the best way to implement it, since the WebOS TV integration does not provide a “Remote” Entity that the Astrion remote can communicate with natively.
An example script would look something like the following, though I haven’t tested it it should be similar, probably possible to build one with the GUI to get the names right then duplicate it and edit in the scripts.yaml file to make each one as needed.
script:
LGTV_Home_Button:
sequence:
- action: webostv.button
target:
entity_id: media_player.your_lgtv
data:
button: "HOME"
alias: LGTV_Home
This could also be done with a nodered flow to make mapping out all the buttons a bit easier if multiple media devices need to be combined with a context aware event for each one.
You will be using the Astrion to control your Harmony Hub, not replace.
Flow for button.* entities to route to the correct Harmony Activity
Harmony Hub Button Mapper & Home Assistant
Scripts then contain the button entities above
Scripts finally mapped to the TV ROS Card
That is one complicated setup. Thanks for sharing. I dont have Node Red setup but maybe there is a blueprint for HA.
@Charles Are there any plans to make this easier in the upcoming firmware update?
Personally I find the NodeRed solutions to be simpler, even though they can look complex. Easier than pages and pages of custom scripts and automations in HA, it puts everything into visual flows.
If you want a pure HA solution just use the LG WebOS integration I mentioned above.
I agree, NodeRED you can visually see where everything is (rather than trying to keep track of it in your head. Then you are just wrapping those buttons into scripts in HA.
@trumee You can just import the button mapper straight into NodeRED with the link I provided you. It will give you the skeleton of what you need. You will just have to edit the nodes for your use. Harmony nodes to control your LG TV need to be changed for your harmony hub and activity. The buttons right at the start of the flow are the button entities that you will wrap in scripts for use in Astrion.
I can upload a more clearly labeled flow to make it easier for you to implement.
Pretty well ALL my automations run from NodeRED, once you start using it, you will not look back.
