Hi @stealthwang,
Thank you for bringing this up. This is actually a topic we’ve discussed internally several times.
From our current understanding, native Bluetooth HID (Human Interface Device) support on standard Android systems became much more mature starting around Android 9. The current Astrion hardware platform is based on the MTK6580 solution running Android 8.1, and unfortunately MediaTek did not fully implement Bluetooth HID host/device functionality at the platform level for this chipset.
Many Android phones and tablets that supported Bluetooth remote-control functions on older Android versions often relied on manufacturer-specific customizations, additional Bluetooth stacks, or proprietary firmware modifications rather than standard Android functionality.
That said, we completely understand your concern regarding Android TV control latency. Using Home Assistant’s ADB integration introduces multiple layers:
Astrion → Home Assistant → ADB Integration → Android TV
which inevitably adds delay compared to direct communication methods such as:
Harmony Hub
NVIDIA Shield Remote
Bluetooth HID remotes
Dedicated IR remotes
For navigation-heavy use cases, especially on devices like the NVIDIA Shield, direct Bluetooth control would certainly provide a much better experience.
May I ask whether your Android TV device also supports infrared control?
One reason we’re asking is that we are currently working on an infrared-enabled Astrion hardware variant based on the current hardware infrastructure. For devices with IR support, this would allow Astrion to send commands directly without requiring Home Assistant, network communication, or ADB, resulting in significantly faster response times and behavior much closer to traditional AV remotes.
We are also continuing to evaluate future hardware platforms with more advanced Bluetooth capabilities, since direct Bluetooth control remains one of the most frequently requested features from power users and former Harmony users.
If you’re using a specific device such as a NVIDIA Shield TV, we’d love to hear more about your setup and the response times you’re currently seeing with the ADB integration. Real-world feedback helps us prioritize future development efforts and hardware roadmaps.
Thanks again for the valuable suggestion!
