1.
TV Card – Custom UI & Source Switching
Issue
TV card has limited visual customization
Cannot:
Add custom images per TV/device
Add grouped or nested controls inside the TV card
Source switching is not user-friendly
Request
Allow:
Custom images for TV cards
Ability to add multiple buttons/cards inside the TV card
Example
Inside one TV card:
Netflix -
DSTV / Sky -
HDMI inputs
Everything inside one TV card so you can switch sources easily without leaving the card.
2.
Buttons + Icons
Issue
Cannot properly:
Add buttons
Add icons to buttons
Request
Allow:
Adding buttons inside cards
Assigning icons to those buttons
Naming/labeling buttons
Example
Inside TV card:
Netflix -
DSTV -
Gaming
Makes the system much easier for clients to use.
3.
Buttons Inside TV Card (Main Point)
Issue
TV card currently only allows:
Scripts
Media player actions
Cannot add buttons (entities) as a control option
Request
Add support for buttons inside the TV card
Buttons must be able to trigger:
Scripts
Media players
Buttons (entities)
Example
Inside TV card:
Volume Up (button) -
Volume Down (button) -
Power (button) -
Netflix (media/source)
Key point:
Not just scripts or media players — buttons must also be supported inside the TV card.
4.
Amplifier Control Issue (Denon)
Issue
Denon appears as:
media_player
But the system expects:
remote_id
Result:
Cannot control the amplifier from the TV card
Media card only handles playback, not control
Important context:
- The amplifier is network controlled (IP-controlled)
Request
Allow control of
media_playerdirectly from the TV card -
Or allow buttons to control it
Example
Volume up/down
Input switching
Power on/off
5.
Kodi Navigation Not Working (Critical Bug)
Issue
Using TV card with Kodi:
- Navigation does not work at all
What doesn’t work
Up
Down
Left
Right
Select / OK
No response from Kodi
Impact
Cannot control Kodi from the TV card
Breaks cinema room usability
Request
Fix navigation support for Kodi inside the TV card
Expected Behaviour
Full working navigation:
Up / Down / Left / Right
Select / OK
Back
Summary
TV card must support:
Custom images
Nested controls inside the card
Must allow:
Buttons inside the TV card
Icons on buttons
Must support:
Scripts
Media players
Buttons (entities)
Must allow proper control of network-controlled devices like amplifiers
Kodi navigation must be fixed (currently not working)
