🧩 Experimental ideas & development feedback
The TV ROS Card should be able to to be pre-programmed with commands from LG webOS TV integration. For me personally I could use it but I use my LG TV as a display only and feed components (Shield TV and Oppo 205) into it.
Other major TV / Media Servers that could be added are:
Hi Datortarps :waving_hand:
First of all, welcome to the community — and thank you for the kind words. Really glad to hear you’re enjoying both the RosCard and the remote :raising_hands:
Appreciate you taking the time to share such structured feedback. I’ll respond to your points one by one:
:control_knobs: RosCard – Button-style UI
Yes, this is very aligned with our current direction.
We are actively working toward making the RosCard more UI-flexible and entity-driven, including:
  • custom buttons inside cards
  • richer layout composition
  • better grouping of controls per device / activity
The goal is exactly what you described: more “control surface” flexibility, less rigid templates.
:television: LG TV support
Good point — and also a common request.
We already see strong demand for native integrations across:
  • LG webOS (Home Assistant LG webOS TV integration)
  • Sony Bravia
  • Samsung Smart TV
Our direction here is not to hard-code per-brand cards, but to ensure the TV ROS Card can properly consume standard HA media entities, so integrations like LG webOS become plug-and-play through Home Assistant itself.
That said, we are actively reviewing optimizations for major platforms.
:alarm_clock: Clock / alarm on remote display
This is an interesting one because it touches both UX and product positioning.
We already support basic screensaver clock behavior, and we agree that:
  • “always-on clock while charging”
  • optional alarm functionality
…could be valuable for bedside use cases.
At the same time, we’re balancing this with the primary design intent (media + home control), so this may come as an optional mode rather than default behavior.
:repeat_button: Two-way remote integration (very important point)
We strongly agree here.
What you’re describing:
  • battery status reporting
  • find-my-remote
  • room/context awareness
  • brightness control via HA automations
…is exactly the direction we are moving toward.
We are working on a two-way state sync model between HA and Astrion, so the remote is not just a controller, but also a visible, manageable device inside the smart home ecosystem.
:compass: Overall direction
Your feedback aligns very well with what we are already prioritising:
  • richer RosCard UI model
  • stronger HA-native integration layer
  • more device state visibility (not just control)
  • improved media system compatibility
Thanks again for the thoughtful suggestions — and really appreciate you joining the community at this stage of the product. Feedback like this is exactly what helps shape the next iterations :+1:
