I would like to suggest adding icon support in the Cover Control Card for motorized blinds with adjustable slats, such as:
external horizontal facade blinds with tilting slats
internal venetian blinds with adjustable slats
This use case is currently theoretical on my side, but it has already been verified in Home Assistant. My physical remote is still on the way, so I cannot yet confirm the full real-device behavior in practice.
The reason for this request is that the current card presentation seems to be designed mainly for vertical curtains and drapes. For installations using blinds with adjustable lamellas/slats such as Somfy-driven systems, more suitable iconography would make the UI much clearer and more intuitive.
It would be very helpful to have:
a dedicated icon for venetian blinds
a dedicated icon for external facade blinds
ideally, icons that visually suggest slat tilt / lamella adjustment
Even if this is initially only a visual enhancement, it would better reflect this type of cover in Home Assistant dashboards and improve usability.
Thank you for considering this suggestion.
Robert
