UltraRadio — Internet Radio Client for UltraBARX
A network radio app built for UltraBar bar-display devices (1424×280 ultrawide), powered by the RadioBrowser global station directory. It supports on-device operation and remote control from a PC web console, and integrates with the LineOS plugin system.
Features
  • Global stations: connects to the public RadioBrowser API; tens of thousands of stations searchable by country / language / tag
  • Bar-display terminal: the Android app embeds a WebView terminal UI adapted to the 1424×280 ultrawide resolution, with a landscape always-on NOW PLAYING view
  • PC console: open the control panel in a browser on the same LAN to remotely search / favorite / switch stations / adjust volume; state syncs in real time over WebSocket
  • Audio output switching: one-click toggle between the on-device Speaker and a USB sound card (e.g. AIMIC-M4); full progress feedback during the switch, with automatic recovery on failure
  • Favorites management: favorite stations are persisted, and station logos are automatically fetched and cached
  • LineOS plugin: automatically discovered and launched as a LineOS host plugin; supports host-side Play/Pause actions and a debug console (see docs/LineOS-Plugin-Spec.md)
Terminal UI Console (favorites & playback) Console (search)
Version history
v1.7.1 (2026-09-26) — Audio output switching stability release
  • Fixed audio subsystem crashes during USB / Speaker switching causing long periods of silence and a frozen UI: the stream is stopped and the hardware put into standby before routing is switched; routing commands changed from a command storm to a single send; sound-card node auto-calibration is paused during the switch
  • Added full-screen progress feedback throughout the switch (Pausing output → Switching to…), with automatic playback recovery on failure and a 20-second fallback; a silent zombie-stream watchdog automatically rebuilds the audio stream
  • UI: the Audio Output dialog now uses large horizontal buttons with a gradient-highlighted selected state; the NOW PLAYING status dot is center-aligned; device names are unified as English Speaker
  • Other: removed the EQ equalizer; built-in page static resources are cache-busted so upgrades take effect immediately; fixed switch request parameter parsing
  • Docs: added LineOS plugin integration spec docs/LineOS-Plugin-Spec.md
v1.7.0 (2026-09-12) — LineOS plugin integration release
  • Integrated the LineOS plugin system: manifest auto-discovery & launch, register/describe/options/call protocol, host-side Play/Pause control
  • Plugin debug page and /api/plugin discovery endpoint
