Android file manager + USB drive mount + music playback + APK installer
A file manager purpose-built for the UltraBar ultrawide desktop terminal (1424×280), with automatic scan & mount of internal storage and USB drives,
a landscape card-based file browser, batch copy / cut / delete, background music playback, and a fullscreen image viewer.
Features
- Storage device management — auto-detects internal storage and external USB drives (NTFS / exFAT auto-mount), supports one-click re-scan after hot-plug, and shows capacity usage on cards in real time
- Ultrawide file browsing — a persistent navigation rail on the left (title / breadcrumb path / selection mode) and a
LazyRowvirtualized horizontal card list on the right; stays smooth even with hundreds of files - Complete file operations — long-press to enter multi-select mode; supports select-all, copy, cut, cross-volume paste, delete; dangerous operations show a confirmation dialog, and batch tasks use a fullscreen progress overlay
- Integrated music player — tap an audio file to play; a foreground service supports background playback; a translucent MiniPlayer floating bar + fullscreen player (ID3 cover extraction, seek bar) with AUTO / SPEAKER / USB output device switching; returning to the app auto-restores playback control
- Fullscreen image viewer — tap an image to view it fullscreen, scaled to fit, showing file name / size / time
- One-tap APK install — tap an APK to install via the system PackageInstaller, with FileProvider secure authorization
- Immersive dark theme — deep navy palette + pill-shaped buttons, pixel-adapted to the terminal’s 232dp usable height
Screenshots
File browser — breadcrumb path navigation, colored file-type labels, auto thumbnails for images / audio
Selection mode — long-press to multi-select; floating action bar at the bottom: select-all / copy / cut / delete
Delete confirmation — red warning border + list of files to be deleted, preventing accidental deletion
MiniPlayer — translucent playback bar floating above the file list, control playback while still browsing files
Fullscreen player — album cover, progress bar, prev/next controls, audio output device switch in the top-right
Image viewer — dark overlay fullscreen view; tap blank area or CLOSE to dismiss
Changelog
v1.5 (2026-08-17)
- Added fullscreen image viewer (file name / size / time info + one-tap close)
- MiniPlayer redesigned as a deep-navy translucent gradient floating layer, overlaid on the file list
- Player output switching merged into a dropdown (AUTO / SPEAKER / USB), with optimized progress bar and button spacing
- Fixed playback state not restoring after exiting and re-entering the app; auto-rebinds to the foreground service
- Selection mode action bar changed to a translucent overlay; DELETE button made large red for emphasis
- Compressed the delete confirmation dialog height to avoid buttons being clipped by the ultrawide bottom edge
- SCAN button text changed to white; home subtitle changed to “UltraBAR Edition”
v1.4 (2026-08-16)
- Integrated music player: PlaybackService foreground service + MediaStyle notification
- Added MiniPlayer floating bar and fullscreen player (cover extraction / seek / queue playback)
- Supports AUTO / speaker / USB audio output routing
- Completed batch file operations: copy / cut / paste / delete with operation progress overlay
v1.3 (2026-08-15)
- UI layer fully rewritten from WebView (HTML/CSS/JS) to Jetpack Compose
LazyRowvirtualized list replaces DOM rendering, completely fixing frame drops in large directories- Coil async image thumbnail loading replaces the previous base64 transfer approach
- Fixed file list scrollbar desync, card positioning offset and other layout issues
v1.2 (2026-08-10)
- WebView architecture version optimizations, fixed several storage scanning and file browsing issues
v1.0 (2026-08-10)
- First official release: internal storage / USB volume scan & mount, file browsing and basic file operations
