Dear ,
Thank you for your excellent and highly relevant question.
Your assumption is largely correct. The most common “one-touch startup” technologies on the market (like Wake-on-LAN) are primarily designed for the Windows/PC ecosystem and often have unreliable compatibility with modern Macs, especially those with Apple Silicon.
However, we have prepared a robust hardware-level solution for you that works flawlessly with any Mac equipped with a wired Ethernet port.
Here’s how it works:
- Core Hardware: The key is our CoreBar Intelligent Control Hub module. It’s not just a controller, but a mini-computer with its own independent network connection.
- Connection Method: The CoreBAR connects to your local network via a universal, driver-free USB-C to Ethernet adapter. This is a plug-and-play solution that provides the CoreBAR with a much more stable and reliable network channel than Wi-Fi, connecting it directly to your local router. Crucially, your Mac must also be connected via an Ethernet cable to the same network.
- Execution Process: When you press the “Engine Start” key on your UltraBar X, the CoreBar sends a special “Magic Packet” to your Mac’s unique network address.
- One-Time Setup: You only need to perform a simple, one-time setup on your Mac: enable “Wake for network access” or “Wake On Lan” in
System Settings > Network > [Your Network Service] > Details... > Hardware.
Once configured, pressing the VivoCube will trigger the CoreBar to send the signal over the wired network, waking your Mac from sleep or even starting it up from a soft shutdown.
What about Macs without an Ethernet port?
For modern MacBooks or Mac Studios that rely solely on Wi-Fi, the “Wake-on-LAN” feature is often unavailable or unreliable. For these users, we recommend using “Sleep” mode (for MacBooks, you can enable “Prevent automatic sleeping when the display is off” in the Battery settings). This keeps the Mac in a low-power state with the lid closed. At this point, you can use the UltraBar X’s USB connection to wake the Mac instantly when any key is pressed, providing an experience nearly identical to “one-touch startup.”
In summary:
- Macs with Ethernet ports: Fully supported and works perfectly. Use the CoreBar for network startup.
- Wi-Fi only Macs: We recommend using the highly responsive “Sleep/Wake” function, which delivers an almost identical “instant-on” experience.
Please find the wake-up process diagram at: https://ultrabarx.sanytron.com/mac/mac.htm.
The core value of the UltraBar X is to create a seamless and ritualistic start to your work session. We are committed to delivering this experience to all users, regardless of their platform.
You can learn more about the technical heart of our system, the CoreBar (Intelligent Control Hub) module, on our product page.
The UltraBar X Team
