Android landscape high-speed dodging · three modes · power-up system · ultrawide immersive adaptation
A space-dodging casual game designed for ultrawide desktop displays. Pilot your fighter through meteors, asteroids, planets and comets at high speed, swipe left and right to dodge the falling celestial bodies, and use power-ups like invincibility, slow-motion and shields to chase a higher score.
Screenshots
Classic mode — horizontal gameplay, obstacles fall from above, background hue shifts level by level.
Vertical mode — the fighter moves to the right, celestial bodies approach horizontally from the left, testing your up-and-down reflexes.
Challenge mode — from level 4 the direction switches randomly; the fighter smoothly flies to its new position, with a full difficulty upgrade.
Game features
- Three gameplay modes: Classic, Vertical, Challenge — each mode records its own high score independently.
- Six power-up system: Invincibility, Shrink, Slow Motion, Shield, Coin, Super Armor — drop randomly for an instant comeback.
- Rich celestial obstacles: four forms — irregular meteors, asteroids, ringed planets, comets — and some obstacles even fly diagonally.
- Dynamic gradient background: background color cycles through six hues level by level; the higher the level, the darker and more dangerous the tone.
- Immersive audio-visual feedback: particle explosions, screen shake, engine trails, paired with background music and multiple sound effects.
- Ultrawide fullscreen adaptation: hides status / navigation bars, blocks system edge gestures, enters fullscreen immediately; auto-pauses when sent to background.
- Local high-score save: high scores are persisted via
localStorage, with a special prompt when you break a record.
Game modes
| Mode | Direction | Obstacle source | Description |
| CLASSIC | Horizontal | Top to bottom | Basic gameplay, good for learning controls and steady scoring. |
| VERTICAL | Vertical | Left to right | Fighter sits on the right, swipe up/down to dodge horizontally incoming bodies. |
| CHALLENGE | Horizontal / vertical switch | Changes with direction | Direction is forced to switch at level 4, then has a 30% chance to switch randomly each level. |
Every 15 points advances one level; the higher the level, the faster the obstacles.
Power-ups
| Power-up | Icon | Duration | Effect |
| Invincible INVINCIBLE | ★ | 10 s | Smash through obstacles directly, +5 points each. |
| Shrink SHRINK | ▼ | 10 s | Fighter size halved, easier to slip through gaps. |
| Slow Mo SLOW MO | 4 s | Whole-field speed drops to 40%, take your time to maneuver. | |
| Shield SHIELD | ◈ | One-time | Blocks one collision hit then disappears. |
| Coin COIN | ◉ | Instant | +10 points immediately on pickup. |
| Super Armor ARMOR | ✦ | 8 s | Smash through obstacles, an enhanced version of Invincibility. |
Controls
- Start game: tap any of the
CLASSIC/VERTICAL/CHALLENGEmode buttons on the main menu. - Move fighter: press and drag left/right (up/down in Vertical mode); the fighter follows your finger.
- Pause / resume: tap the pause button in the bottom-left corner.
- Mute toggle: tap the speaker button in the top-right corner.
- Game over: choose
RETRYto try again immediately orBACKto return to the main menu.
Version history
| Version | Main updates |
| 1.13 (current) | Optimized Challenge mode direction-switch logic and fighter smooth-flight animation; six-color dynamic background cycle; power-up and sound-effect balance tweaks. |
| 1.12 | Introduced the six power-up system (Invincibility / Shrink / Slow Mo / Shield / Coin / Super Armor), with random drops and activation hints. |
| 1.11 | Added Vertical and Challenge modes; each of the three modes saves its own high score; Challenge mode supports random direction switching between levels. |
| 1.10 | Obstacles upgraded to four celestial forms (meteor / asteroid / planet / comet); added planetary rings and diagonal flight. |
| 1.9 | Added level-based color-changing dynamic gradient background, particle explosions and screen-shake feedback. |
| 1.8 | Fullscreen immersive adaptation: hide system bars, block edge gestures, auto-pause on background. |
| 1.0 | Early casual game prototype, later rebuilt into HTML5 Canvas-driven space-dodging gameplay. |
