BÆOREMOTE 1.6: new features, and reliability fixes for a failing eMMC (part or repair question for the team)
Hi all,
BÆOREMOTE 1.6 is out. Part of it is new features. The bigger part is reliability work, because one of my two HA100s has a failing eMMC and I had to make the app survive it. There’s a hardware question for the team at the end.
What’s new
The mirror ball spins on the floorplan and throws specks around the room, and blinds are drawn as far down as they really are:
Mirror ball and blinds
Vacuum with its live map Light groups with colour Zones and BÆOLINK
  • Music: a Recently played shelf, every Sonos favourite in the library, and shelves that load instantly when you come back to the page.
  • Floorplan: recolor shows one light colour as another on the plan only, so a scene’s mint green doesn’t clash with teal LED strips.
  • Snappier on the dock: Wi-Fi power save turns off while docked (pings roughly halved) and back on when you lift it. Thanks to @Aurelien_PERARD, whose fork gave me the idea.
  • Lighter docked load: the mirror ball, ambient art and radar dots all draw less.
Reliability, and why
Over one week, the newer of my two remotes boot-looped three times. Each time I found files on the flash that had been fine before and were now corrupt. It turned out every loop followed a reboot of a remote that only looked frozen after Home Assistant went down, and a reboot is exactly when Android re-reads everything from the failing flash. So 1.6 makes reboots unnecessary and keeps writes off the flash:
  • Heals its own HA connection. No more “Connecting…” forever after HA restarts or the Wi-Fi drops. A watchdog reconnects, and the app never needs a reboot to recover.
  • Writes almost nothing to flash. The art cache and saved state live in RAM, and cover reads no longer touch the disk.
  • Can’t be boot-looped by a rotten cache. A small boot script clears Android’s package cache, and moves aside any cache file with unreadable sectors, before the system starts.
  • Sanytron’s launcher stays home. HaRemote remains the home app, since the HA100 needs it there. I open BÆOREMOTE with a held Back key.
Everything is on GitHub: GitHub - baes-cloud/astrion-dashboard: A fast, native Home Assistant dashboard for the Sanytron Astrion HA100 smart remote. · GitHub
The flash problem: a question for the team
The failing remote is the newer of the two, which surprised me. Both have been used side by side every day, with the same firmware (HAOS V1.0.3), the same dock setup and the same apps, and the older one is perfectly healthy.
What I’ve seen on the newer one (serial 0127#########421):
  • Three boot loops (26 Oct, 30 Oct, 2 Nov). Corrupt files each time: /system/framework and dex2oat once, Android’s package_cache another time, and the floorplan image twice.
  • Reading the same file twice can give different results. Bad sectors come back as a repeating de ad ad de pattern, with nothing in the kernel log.
  • ext_csd shows PRE_EOL_INFO 0x02 (warning) here, against 0x01 on the healthy one. The wear estimate (LIFE_TIME_EST) is 0x01 on both, so it isn’t worn out by writes.
  • About three times as many retired blocks as the healthy remote.
I’ve kept it going by reflashing /system from the healthy unit, plus the fixes above, but it’s living on borrowed time. Could you help with any of these?
  1. Is this a known issue with a batch of the Samsung KMQ7X000SA eMCP?
  2. Is a replacement mainboard, or the eMCP part itself, available to buy?
  3. Is there a repair or exchange route for a remote in this state?
  4. Any guidance on the official full-flash procedure (SP Flash Tool) for after the chip is replaced?
Happy to send logs, the ext_csd dump, photos or anything else that helps. Thanks for making hardware this open to tinker with. It’s been a joy.
Bae
